Page 3 of 4
Re: W/NG Front Brake Cam
Posted: Sun Jul 15, 2018 4:23 am
by nevhunter
2 and 7/8 inches Luis (between CENTRES). Give it a 1/8th inch offset away from the backplate also. I think the 2 7/8 is a bit longer then the standard girder fork brake arm to clear the wheel driven speedo the W/NG has. Nev
Posted: Sun Jul 15, 2018 10:47 pm
by LuisPaz
Nev
Thank you very much for the measures!
Your comments are very appreciated and accurate!
The external diameter of the shoes was 155mm.
The internal diameter of the drum is 165 mm, so I think the lining would be 5 mm thick.
Best regards!
Posted: Mon Jul 16, 2018 2:41 am
by nevhunter
That Drum diameter is close to standard size which is 6.5 inches in Imperial measures. I hope you get the sort of pleasure from your W/NG as I have from mine Luis. I first put it on the road about 1998 . 20 years with not even the head off it again. Rear chain and rear tyre. That's all. Nev
Posted: Thu Jul 26, 2018 2:55 pm
by LuisPaz
Hi Nev
I hope to have the same results as you!
The ferodos are stick and brakes ready to install !
Surely I will have to make more adjustments ...
Posted: Sun Jul 29, 2018 3:14 am
by LuisPaz
Today assembly all the parts and the brakes are ready to work!!
Regards!
Posted: Sun Jul 29, 2018 2:06 pm
by Simon.Gardiner
Really nice work Luis!
Posted: Mon Jul 30, 2018 2:52 pm
by LuisPaz
Thank you Simon!
Regards!
Posted: Sun Apr 10, 2022 3:20 am
by tcolbourne
Hi Luis,
I got a 1943 W/NG a few months back that was a daily driver in Burma (Myanmar) until a few years ago-still has mud on it from Myanmar--and i'm looking for similar front brake parts--i have the shoes, springs and plate-and speedo drive-but need the brake came and bushing that bolts onto the plate as mentioned in your excellent article. I do have the cam lever (actuator)-which i got from Europe (France I think?). If you have any spare front W/NG brake cams and assorted washers etc. please let me know.
Tom Colbourne
tomcolbourne2016@gmail.com
Canada
Posted: Mon Apr 11, 2022 7:21 am
by Andy H
Single spares had a few bits yesterday,may be worth a message.
Posted: Mon Feb 06, 2023 3:55 pm
by Richard Woolnough
would the cam be hardened?
