ARIEL MF
marwsk
Post by marwsk »
whether such a wheel could be installed in mf ariel year 32?
allegro.pl/kierownica-ariel-i2635326395.html
Knud.Degnbol
Re: ARIEL MF
Post by Knud.Degnbol »
Do you mean the handlebar? It is not for an Ariel. It will look completely out of place.
Knud
brenton.roy
Post by brenton.roy »
Have a look at Paul's sloper rebuild. The handlebars should be the same / similar.
http://forum.arielownersmcc.com/viewtopic.php?t=497
marwsk
Re: ARIEL MF
Post by marwsk »
some pictures of my Ariel from today. engine main problem is the lack of the crankshaft and clutch housing. Besides the clutch is complete. from what I can see in the pictures is the most fender mounts and the gearbox housing. I think the trunk is non-genuine. English saddle. the frame is not damaged, do not cut and welded.
marwsk
Post by marwsk »
brenton.roy
Thanks for the photo's. You've got some work to do!
I think the primary cases are going to be very hard to find. A temporary fix is to use a steel outer primary cover as used in early 30's Ariels. AJS and Norton are close / similar.
If the trunk is the petrol tank, I don't think it's repro.
I hope you can find a crank assembly. At worst, if you can find the mainshafts, you might be able to have the rest made up.
regards, Brenton
marwsk
Post by marwsk »
Can someone show how the original wheels for this model? I found a few dealers in Poland and have made ​​me an offer with pictures - but I do not know how they look like wheels. Is the fender below is the correct shape for the model 32?I'm waiting for a few parts that I bought recently: Oiltank, rearstand, chainguard, battery carrier. Engine off missing shaft is in very good condition.
adrie.degraaff
Re: ARIEL MF
Post by adrie.degraaff »
My 1932 MB has the same parts, I sold it via "Yesterdays antique motorcycles", you can still see it on "archive".
marwsk
Post by marwsk »
I'm looking for a parts catalog / errata to the MF version of the 32. I am interested in the differences in the wheels and faders because I think that there are several types.
adrie.degraaff
Re: ARIEL MF
1931 and 1932
