Page 3 of 9
Re: 1946 VH 500 Restoration
Posted: Fri Dec 13, 2024 5:23 pm
by KenS
Roger Gwynn wrote: Fri Dec 13, 2024 3:54 pm Scroll down the page and you will find applications and colours.
Either red or blue shading, TRA-20 or 21 (excuse the misprint in the caption) I would expect the red to be used on red tanks, normally found on Hunters and the Blue on other models. Incidentally the first enamel badge in 1934 had blue shading, changed the following year to black when the red shaded ones were invented for the Hunters.
Roger, I have measured my tank recess where the transfer will go and I'm headed to my sign shop to see if they can make some for me. Can you tell me the what the blue color shade or code is please? The TRA-20 is no longer available at Dragonfly.
Posted: Fri Dec 13, 2024 5:46 pm
by Simon.Gardiner
Looks like Jerry has these available under Club Regalia. ;)
See the details on the spares page
https://www.arielownersmcc.com/members_only/spares.html
Posted: Fri Dec 13, 2024 9:44 pm
by KenS
I went to our local sign shop and ordered 4. Here is the proof for the printed Vinyl covered with a clear film.
Posted: Fri Dec 13, 2024 10:06 pm
by Roger Gwynn
Using transfers would be the easiest and most accurate route and a talking point down the pub!
Posted: Fri Dec 13, 2024 10:08 pm
by Roger Gwynn
Sorry i don't know what shade of blue Ariel used.
Posted: Fri Dec 13, 2024 10:16 pm
by KenS
Roger Gwynn wrote: Fri Dec 13, 2024 10:08 pm Sorry i don't know what shade of blue Ariel used.
No problem Roger, at lease I'll have the badges on the tank moving forward!
Posted: Wed Dec 18, 2024 8:24 pm
by KenS
Progress after having the period transfers made, and applied.
Posted: Thu Dec 19, 2024 3:58 pm
by paul.jameson
Obviously, I don't know if your transfers are the same type as the ones I used some years ago, but mine washed off in the first rainstorm, which was disappointing. Taking advice from Jerry Mortimore, I have subsequently always varnished over transfers using a Humbrol enamel clear varnish and had no problems since.
Posted: Thu Dec 19, 2024 4:10 pm
by KenS
Hi Paul, These are printed on an adhesive backed Vinyl, covered with a clear vinyl and sealed. I was told by the sign shop that they should last many years if not subjected to harsh chemicals. Application was a breeze, and should I need to replace them, it will be easy as well by using an adhesive solvent that will not effect the paint.
Now that I have paid for the art work setup to produce the file, printing more will be around $11 each,
Posted: Thu Dec 19, 2024 6:10 pm
by Julian Murphy
Dont spill 5 or 10% ethanol petrol on them... :!:
