Page 3 of 3
Re: 557 SV piston
Posted: Thu Sep 19, 2024 9:11 am
by tony.barnett
Ray - did you have any joy finding a suitable replacement piston? I'm looking too now.
Re: 557 SV piston
Posted: Fri Sep 20, 2024 2:53 pm
by RayBlack
Hi Tony. The only source of repro piston I could find is JP. They appear to have standard up to +40 sizes. The barrel I have is in pretty poor shape so I am still keeping an eye out for another with not so many broken fins to repair (yes, I know, good luck with that...). I am also remaining optimistic there are a few Hepolite 1109s out there still waiting to be discovered.
Re: 557 SV piston
Posted: Mon Sep 23, 2024 9:31 am
by tony.barnett
I'm going to try to rescue my standard piston - the top groove has spread a little so the clearance now is causing rings to break - I'm going to widen it a tad and get a wider ring made to fit. If not it'll be rebore and JP. I'll keep an eye out for 1109 pistons.
Re: 557 SV piston
Posted: Tue Sep 24, 2024 12:30 am
by nevhunter
You can put two rings in the widened groove. Works fine. Nev
Re: 557 SV piston
Posted: Tue Sep 24, 2024 4:06 pm
by tony.barnett
nevhunter wrote: Tue Sep 24, 2024 12:30 am
Its been running for ten years with two 1/16" compression rings in the top groove, but after an `episode' it appears to have spread the groove a little so there is too much play now and its breaking rings.
Re: 557 SV piston
Posted: Wed Sep 25, 2024 9:05 am
by nevhunter
It won't wear the groove any more than with a single ring. Carbon in the groove or not enough end gap breaks rings. SV motors run very hot especially near the exhaust port. A "twisted" con rod will make the rings wear more and having no air cleaner. Nev
