Square Four MkI restoration complete - almost....
Re: Square Four MkI restoration complete - almost....
Gave up for today. Today she didn't fire once. After a few attempts the plugs are definitely wet. Still not sure why she is not strating. Too advanced? Too retarded? Too rich and flooding?
I'll try Paul Jameson's method next time and re check the timing. Thanks for all the tips as always.
Gui
Gui
1951 Ariel Square Four MKI
1954 Ariel NH Red Hunter
1929 BSA Sloper
1946 BSA B31 (project)
1954 BSA C11G
1960 Harley Sportster XLH
1951 Harley WL 45
1929 BSA Sloper
1954 BSA C11G
1951 Harley WL 45
Re. The timing. You've checked both the ignition and the valve timing? I got the valve timing wrong several times when I built my engine. I found it quite confusing that the crankshafts roll in different directions.
Yes, valve timing according to Bruce Longmann's method and it was spot on to maybe 1 deg. I had to repeat it about 3 times before I got it, and did get confused as well at the beginning. Again,I believe it's something with the mixture because she ran twice for a few seconds before going out and didn't sound that bad. If either the valve or ignition timing was completely off, she wouldn't have run at all. I'll just have to keep at it.
1929 BSA Sloper
1954 BSA C11G
1951 Harley WL 45
1929 BSA Sloper
1954 BSA C11G
1951 Harley WL 45
I think you're right. Mine is not so easy to kick over from cold, and it was worse when the engine was tight. Those seven Maudes Trophy schoolboys must have either been pretty hefty or been kicking over a hot engine.Gui.dorey wrote:I'll just have to keep at it.
Another thought - I have my kickstart mounted just high enough to clear the toolbox and even then I start the kick from maybe 10 o'clock, to maximise torque on the starter. Of course, this limits the amount the engine turns over.
Last edited by simon.holyfield on Mon Apr 29, 2019 7:34 am, edited 1 time in total.
john.whiting
in those days schoolboys played 50 a side rugger every afternoon on fields of bare pebbles,and had cold showers to keep their minds on Greek and Latin..........so maybe they were putting some force into the crank.
- Bob.Murphy
Ah yes; I remember those days (Boarding School in the 50's)john.whiting wrote:in those days schoolboys played 50 a side rugger every afternoon on fields of bare pebbles, and had cold showers to keep their minds on Greek and Latin.........
The schoolboys were kicking over a Cammy, so 600cc at most with easy to turn roller big ends and ball mains. A 1000cc engine with lots of whitemetal bearings is much more difficult to turn.
Ian.McCandlish
Sorry I'm a bit late to the party, but I find my '49 Sq.4 starts with the bi-starter halfway out and with the throttle slightly open. I always give it 4 kicks with the ignition off to get some fuel into the cylinders, then off we go! If I try to start it with the lever fully out it wont go!
Old bikes are like people they all have their own foibles
Ian
Ian
Uhuuuuuu!!! She‘s running!!!
Sorry for the poor video but not enough hands
In the end it went like this:
Tried Paul Jameson‘s trick and she fired, but didn‘t start.
Re tried a few times and sometimes she would fire, sometimes not.
I then closed the bistartet completely and opened up the throttle a bit. After a few attempts she finally burst to life with an amazing sound!
She would want to die however if I closed the throttle, until I pulled the bi-starter to the mid position. She then seemed to be happy that way. Then I noticed the massive oil leak at the front of the engine and shut her off immediately and the fun was over. The oil line to the rockers came apart at the soldered seam near the fastening to the rocker box. so will have to fix that. Didn‘t have time to check the pressure gauge either.
Very excited but time to rest my kicking leg. It‘s been a looong time since my rugby days as second row, but I do notice my leg muscles are coming back - nearly ready for the scrum, I‘d say.
- Attachments
- D275EB88-5455-49FD-9A73-4A652548A6D4.MOV
- (16.62 MiB) Downloaded 1730 times
1929 BSA Sloper
1954 BSA C11G
1951 Harley WL 45
1929 BSA Sloper
1954 BSA C11G
1951 Harley WL 45
Excellent news Gui, well done!
I had a oil line with a duff joint too. Couple of tips: did you use a copper washer at the rocker box joint? A fibre one lasts for a while but will eventually burn and leak.
Secondly, do you have the rocker oil line and the gauge line the right way round? Contrary to what you might expect, the gauge is the larger of the two.
