Page 2 of 2
Re: 58 VH 500 popping out of second gear above 2500-3000 rpm
Posted: Wed Sep 16, 2026 12:47 pm
by dgurovich
Well that's not it then! I think shimming the secondary shaft top hat bushing on the case cover side, or the other side?
Posted: Wed Sep 16, 2026 6:31 pm
by simon.holyfield
dgurovich wrote: Wed Sep 16, 2026 12:47 pm Well that's not it then! I think shimming the secondary shaft top hat bushing on the case cover side, or the other side?
Might I suggest you measure the endfloat for the mainshaft, layshaft and sleeve gear? There's a lot of expertise in the club (not me!) that has helped me hugely with problems like this...
Posted: Thu Sep 17, 2026 5:46 pm
by dgurovich
Is there instructions for accurately measuring end float? I'm new to transmissions and I'm comfortable with assembly/dissasembly, but the finer points are still kind of new to me.
Posted: Thu Sep 17, 2026 8:48 pm
by simon.holyfield
This should help. The guage is called a Dial Test Indicator here in the UK - there is a plunger which moves in and out and makes the needle go around on the gauge to show you how much the plunger has moved. In this picture I have the plunger in contact with the end of the sleeve gear.
DTIs are used with a magnetic stand, which is sitting on one of the engine plates.
You push the shaft in one direction, set the gauge to zero, and use some sort of lever to push the shaft in the other direction and measure how much it moves.
Posted: Fri Sep 18, 2026 1:25 am
by dgurovich
I have that tool. I'll dig in!
