Re: Wanted - 1 x Pushrod 11-1/8" for 1933 VH500
Posted: Thu Sep 10, 2026 9:14 am
Where did you find that? I looked everywhere when I needed to make a pushrod - couldn't find anything which wasn't in the US and a daft price.Pete.Silson wrote: Wed Sep 09, 2026 6:17 pm The best (closest to the original) tubing I have found is 4130 Chromoly Steel, OD = 7/16”, ID= 3/8”, Thickness = 1/32” (21G).
4130 alloy tube is readily available. It is used in aircraft and vehicle frames and is extremely stiff and thermally stable. The size above is virtually the same weight and thermal expansion as the original tubing. I simply use a slide hammer to remove the end fittings from a donor pushrod and press them back onto new tube.
