Wanted 1-5/8" x 20 tap
- Bernie Blundell
Re: Wanted 1-5/8" x 20 tap
Try messaging >>> https://www.ebay.co.uk/itm/382958190347 ... R4SpkKjmZg ... see if it can be posted to you
AN advantage of CEI is that the tpi doesn't change or rather most larger diameters are all 20 tpi so could you not use any large tap to carefully scrape the thread to repair it? Alternatively there are thread chasers like these https://www.ebay.co.uk/itm/314702039169 ... ZQ95QTH3C3
Add a thicker fibre washer under the cap ?
Turn X mm off the botton of the cap thread ?
