1930/40s Ariel single wanted
Re: 1930/40s Ariel single wanted
There wasn't a VA in 1931, only the VB and it had a Sturmey gearbox, so it looks correct and is much like the later VA3 but that used a Burman T gearbox. In fact the 1931 VB is the only 2 letter model to use a Sturmey gearbox, not many people know that .... or care! There are only 3 others with Sturmey gearboxes, so not that amazing.
Yes, strange to put the pedal on that side, perhaps a hang over from the left foot clutch and right brake, last seen in 1925, but why change? There was a MKII SQ4 built in 1956 with a right brake pedal, drawing available.
klaus gerhard
Post by klaus gerhard »
All right VB31 not VA31. To my knowledge all 1931 Ariel bikes had the footbrake pedal on the right.
Post by Paul Slootheer »
Klaus it seems you are right… But apparently Ariel changend that position later on again to the left?!?
Yes in 1932 it went back to the left. The Slopers/4F used a shaft through the frame for both years, essentially a dummy one in 1932.
markus.nikot
Post by markus.nikot »
Thanks for that, but Tom is looking for a foot gearchanged bike.
AOMCC German Branch Secretary
some Ariel - only Ariel
