Page 2 of 2
Re: Two stroke oil
Posted: Tue Sep 08, 2026 2:38 am
by nevhunter
A cast iron cylinder which is air cooled for a reasonably high performance engine is the Most critical two stroke Lubrication situation for HEAT Ie Ring groove carboning and more oil with Premix also leans the Mixture Some TS oils contain a mixant which is not oil and makes the Oil seem thin when in the container.. If mixing in the tank shut the fuel cocks off first and vigorously shake the bike before turning the fuel on. Its preferred to mix in a separate container. Nev
