Here we go again....
Pictures (or stories) of hideous injuries sustained by your Ariel
Re: Here we go again....
Post by Paul Slootheer »
A friend of my, who a owns a classic motorcycle repair shop and does reboring and hone as well, first heaths up the piston to a specific temperature (forgot how high…) and measures them. This enables him to see howmuch the piston expands and to what size he must do the rebore.
The Pistons you have NOW are "W" slot A car type piston where every motor is water cooled so the BLOCK doesn't get that hot. When the Block gets really hot that"system" does not work.. What Paul has described is one way of "getting an idea. But the TYPE as well as the Metal makes a lot of difference. Slots stop the heat travelling to the Skirt so the crown runs hotter. The WAY your pistons are grabbing indicates INSUFFICIENT Clearance whatever the clearance IS How many reconditioners are FAMILIAR with AIR cooled Motors these days that are NOT High oil flow motors? These things are seizing up commonly as people use fits that will never survive The fits prescribed by the MAKERS of the TIME are still valid today and remember WE tend to run them Harder because the Modern traffic goes faster.
Post by Simon.Gardiner »
In this case, all the pistons are manufactured specifically for this application (air-cooled motorcycle, BSA/Ariel 650). The manufacturers (JP and Wassell/Hepolite) specify the necessary clearance. Both engineering firms are very familiar with these exact engines, they have done this work before without any issues.
However in this case one lot seem to have cocked-up and bored to only half the specified clearance!
(Presumably the later seizure indicates lack of clearance because there was lack of clearance! However the JP was running in the same bore with the same lack of clearance - JP and Wassells actually specify exactly the same clearance figure.)
We are NOW a very small % of the total market For Piston suppliers and a lot of the Old blokes who Knew about early stuff are Long gone from the ranks Pre WW2, everyone rode Motorcycles and sidecars and they weren't locking up all the time for good reasons which I've outlined, briefly. Most modern stuff is alloy with Nikasil bore and High silicon Pistons and internally showered in OIL. Designed to sit at High speed all day long if required. ALL 50's bikes are is 30's technology with enclosed valves which makes them cool worse.. Recurrent seizures are dangerous and remove metal from cylinders unnecessarily when it has to be rectified. Overbored and sleeved barrels can also Break. It's no fun riding a bike that MIGHT NIP UP on a freeway. Don't risk it. Nev
