Page 2 of 3
Re: WNG Rear Mudguard measures
Posted: Sun Mar 15, 2020 1:15 am
by LuisPaz
Thank You Johnny!
Today continue with the mobile stays
My read mudguard is Frankestain!
The angle is wrong... needs to be corrected
Posted: Sun Mar 15, 2020 8:03 pm
by alan.moore
Looking good Luis
Posted: Tue Mar 17, 2020 12:40 pm
by LuisPaz
Thank You Alan!
The screw to join stays to mudguard are 1/4 " diameter , and what thread?
https://www.draganfly.co.uk/index.php/c ... oduct/537-
Regards!
Posted: Tue Mar 17, 2020 5:42 pm
by JohnnyBeckett
HI Luis i think if they look like a fine thread it is 26 TPI CEI ( CYCLE THREAD ) or if it looks like a course thread it is BSW ( WHITWORTH ) that is the common threads that i use on most of my Ariel's some times i find someone has used different type of bolts and screws if they did not have the right ones like the ARIEL i am doing now it got lots of all different types of nuts and bolts with the wrong threads and nut sizes
Posted: Tue Mar 17, 2020 11:42 pm
by alan.moore
Luis
26 tpi cycle thread, same as the majority of the fastners.
alan
Posted: Wed Mar 18, 2020 7:46 pm
by JohnnyBeckett
HI most of the bolts and screws are 26 TPI but their is some BA as well on the bike but the engine and gearbox are mostly BSW
Posted: Sun Jun 28, 2020 3:20 am
by LuisPaz
I need turning the mudguard stay nut..
Can tell me the hexagon size?
Thanks in advance!
Posted: Sun Jun 28, 2020 11:48 pm
by LuisPaz
Today working with Lathe . Nut ready to cut and threading. I think this is NO correct nut to WNG because cannot put the pannier frame bracket....
Posted: Mon Jun 29, 2020 10:08 pm
by alan.moore
Adrie
Here are the two nuts from my WNG, as far as I know they are original. I had a problem in that with the pannier mounting brackets fitted I could not get a spanner on these nuts as they were too big. I then used two half width normal size 5/16 nuts with washers for the raised part to solve the problem.
Alan
Posted: Mon Jun 29, 2020 11:28 pm
by LuisPaz
Hi Alan!
Thank you very much for your help!
My head nut have 21/32.... they are a pair of bolts that I found in the waste can!
