KH 500 Camshaft shims
eadriclloyd
Post by eadriclloyd »
Could any one please advise where the camshaft shims should be fitted?
I have just rebuilt the engine and shimmed the camshafts within the crankcases on the timing side.
Both camshafts required a 5 thou and a 15 thou shim inserted between the thrust face of the camshaft and the inside face of the camshaft bush in the timing side crankcase. This gave me 2 thou end float on each camshaft. The sprockets and sprocket nuts were not fitted at this point.
When I tightened the camshaft sprocket nuts, with timing chain fitted, I found that the crankshaft became very difficult to rotate. This is due to the camshaft sprockets pinching on the case/bush behind.
When I dismantled the engine a 4 thou shim was fitted to one camshaft an 8 thou shim fitted to the other.
Should I have fitted the shims behind the camshaft sprocket?
Thanks.
Eddie Lloyd
Re: KH 500 Camshaft shims
I would refer you to page 10 of the 1948 owner's guide, in case you don't have a copy the relevent bit is...
48 kh.docx
(126.72 KiB) Downloaded 95 times
eadriclloyd
Roger, Thanks for the advice and reference in the owners guide.
The engine is back together and seems to be running OK.
Eddie.
