W/NG 275 Carb wanted
Parts needed or for sale, which are unique to the W/NG.
Suppliers of unique Ariel parts.
tcolbourne
Post by tcolbourne »
Hi,
Looking for a 275 carb to fit W/NG--i have what was on the bike when i bought it (a 289 with oval inlet) which was put on at some point in it's life.
thanks,
Tom Colbourne
Re: W/NG 275 Carb wanted
You know you can buy a brand new 276 from Burlen, Tom? It's one size up, but any 275 you are likely to find might be a world of pain.
They do come up though. I have an eBay 275 on mine and it's in very good condition, though with the cam I have in the engine the 276 would probably give me better top end performance.
tcolbourne
thanks for the info. I'll look into Burlen. I have a 1950 NH with a 276 so am quite familiar with those--the only difference i can figure is the 275 is 7/8 bore instead of 1" for the 276? The rest appears the same. The W/NG has a 7/8 bore head of course and quite low compression ratio (the piston is flat top).
tcolbourne
Still looking for a 275 Amal--thanks folks. Any connections appeciated.
tcolbourne wrote: Tue Nov 23, 2021 6:36 pm thanks for the info. I'll look into Burlen. I have a 1950 NH with a 276 so am quite familiar with those--the only difference i can figure is the 275 is 7/8 bore instead of 1" for the 276? The rest appears the same. The W/NG has a 7/8 bore head of course and quite low compression ratio (the piston is flat top).
One of the things that is not so obvious is that the 276 is taller than the 275 - and there is precious little space above the carburettor for the cable adjusters.
tcolbourne
Hi All--fYI i was able to find a 275 carb--still have the 289 if anybody needs one with an oval inlet.
