camshaft spray bar kit
GuyWalton
Post by GuyWalton »
Does anyone have any information on the square four spray bar modification . Pictures would be good .
51 mk1 Areil Square Four
55 DB 500 BSA Gold Star
55 Matchless G9
67 BSA B44
06 Ducati 999R
Paul_Linden
Re: camshaft spray bar kit
Post by Paul_Linden »
Here is a photo of a spray bar fitted before the rear crankshaft is installed and the cases put together. I will add some more words and pics tomorrow.
Spray bar
Spray bar
Paul_Linden
When you click on the above picture it shows it the right way up.
GuyWalton
Post by GuyWalton »
Thanks for that I understand it a bit better now . is the feed taken from the return line .
55 Matchless G9
67 BSA B44
06 Ducati 999R
allan.walker
Post by allan.walker »
That looks interesting. Are these available to buy?
Paul_Linden
The feed is taken from the thin oil pipe to the rocker box by adding a “T” piece. The feed to the spray bar goes into the timing chest then through the crankcase wall to where it is mounted above the camshaft.
Paul_Linden
Here is a picture of the parts that were in the kit provided by the club. The two gauges were not included. This kit is for a mark 2, but I ended up fitting it on a mark 1 but without a gauge.
Spray bar kit
Spray bar kit
Paul_Linden
Here is a test fit of the plumbing on the outside of the cases. A hole was drilled through the cases below the dynamo for the pipe to go inside.
External view, test fit.
Paul_Linden
View inside timing chest.
Paul_Linden
Test fit of the spray bar in the crankcase with only the camshaft in place (crankshafts not fitted). Two holes were drilled in the crankcase bridge to accommodate the spray bar mounting bolts which can be seen with their lock tab. If you look very closely you can just see two of the apertures in the Spray bar where the oil comes out.
