Spark Plugs
NealHooper
Spark Plugs
Post by NealHooper »
Hello, I have a 500 VHA. What spark plug have people found best. It has an NGK in it at present, B6HS, not sure if that is right. Any recommendations.
Neal
Paul_Linden
Re: Spark Plugs
Post by Paul_Linden »
A word to the wise - eB*y appears to be awash with counterfeit spark plugs, so whatever plugs you choose buy them from a reputable company.
Re: Spark Plugs
Post by JohnnyBeckett »
hi Neal, that is a good bit of advice from Paul , buy from a good supplier they may cost a bit more but you are going to-get one that works properly, :D there is lots of counterfeit going around :x
Ian.Taylor
Re: Spark Plugs
Post by Ian.Taylor »
I believe they call for a B6ES but in my VHA I use a B7ES
Re: Spark Plugs
I've always had good experience with the Green Spark Plug Company. You'll get genuine parts from them.
Dave.Thomas
Re: Spark Plugs
Post by Dave.Thomas »
Re: Spark Plugs
I've heard several people say that the Brisk plugs are more soot-tolerant than others.
Re: Spark Plugs
See bottom of this page all the recomendations for Ariels https://draganfly.co.uk/product-categor ... ellaneous/ NGK plug code - 1st leter is diameter B=14mm, the number is the heat range, 2nd letter is length H=short reach, E=long reach, last letter S=super dooper wide range or something.
NealHooper
Re: Spark Plugs
Sound advice there thanks guys. Appreciated.
Re: Spark Plugs
Some heat numbers work the opposite way to others. IF your engine is "hotted up" use a colder plug. I do not recommend using "R" plugs or suppressor leads with a magneto equipped engine. Nev
Users browsing this forum: Ahrefs [Bot] and 7 guests
