Burman GB gearbox
Burman GB gearbox
Greetings from across the pond! I hope you have all weathered the pandemic without getting ill. So far so good here in Canada, no one I know nor clubmates have been stricken with the illness. I come begging for info again, this time for any photo or drawing of the placement of the "Gear change Quadrant Primary Spring". I sent for the booklet from Drags and all it has is a lousy copy of the blowup and no info on placement. Very disappointing as a to any usable info. So far I have searched every book on Ariel and Burman but no assembly information. Anything anyone has would be greatly appreciated. Thank you all and stay well !! Regards, Dave.
Re: Burman GB gearbox
Hi Dave,
Here's a photo of the spring in position on the outer cover - hope it helps !
Rgds
Dave
Rgds
Dave
- chris.shearwood
Hi Dave,
I'm not sure to which spring you mean but by chance I was putting a BA box together today and quit just before putting the outer cover back on. Come on over tomorrow and you can take a look.
Regards, Chris
Regards, Chris
1946 4G and 1951 VH
HI Dave their is a two springs that are for the gear change one is the flat spring that is in the post that Dave has put up and their is a spring that goes on the gear change shaft between the gear change quadrant plate and the outer case and their is a oil seal that goes in the case from the inside of the case before you fit the shaft and their is a good DVD on E BAY about BURMAN gearboxes i am just doing a full rebuild on my on my GB 5 gearbox and i find the gear change shaft wears a lot and gives poor gear change
Thanks Dave, that is how I placed it but my problems are that when I removed the cover things fell out but one pin from the lay shaft side of the shift drum{cam} was missing, the cotter pin as well and those parts were not there..... also someone had put shims between gears on the main shaft. I have no idea who ever worked on it but it did not run like that. I made a new pin. All the bushes were worn out as well so I have replaced them and the bearings and large mainshaft seal. I still haven't found a seal for the kick start shaft {outside } Drags doesn't have it......and it is not a standard or metric size. Also I have looked for the DVD for the GB on Ebay and can't find it.
Thanks to Chris as well for inviting me over { a short drive } He also has a tranny apart but not the same. We had a great visit and i took some photos of his 1950 for reference, he also had some internet addresses for me to check for some of my missing parts.
- keith.mettam
Hi Dave,
I have sent you a personal message with some info attached that may help you.
Good luck with your rebuild,
Keith.
Keith.
HI THE E BAY number for the DVD is 323460896320
AND TRY THE club gearbox spares or john Budgen for parts as well
Thanks again for the help, I will try again to get the DVD on Ebay.
