Its Finished .
GuyWalton
Its Finished .
Post by GuyWalton »
Bought this back in April 19 its took me longer than my gold star but it is done . Two of my five bikes .
51 mk1 Areil Square Four
55 DB 500 BSA Gold Star
55 Matchless G9
67 BSA B44
06 Ducati 999R
Paul_Linden
Re: Its Finished .
Post by Paul_Linden »
Lovely job Guy, something I aspire to do.
paul.ptak
Re: Its Finished .
Post by paul.ptak »
Very nice Guy! Any chance you could share some detailed photos on how you mounted the Rodark panniers? Did you make the mounts or use a mount that was commercially available in the past?
Thanks.
Paul
GuyWalton
Re: Its Finished .
Post by GuyWalton »
paul.ptak wrote:Very nice Guy! Any chance you could share some detailed photos on how you mounted the Rodark panniers? Did you make the mounts or use a mount that was commercially available in the past?
Thanks.
Paul
I made my own mount out of 4mmx25mm flat bar it is mounted at the top mudguard mount goes straight down and hooks over the bottom mudguard stay then goes under the panniers and is bolted front and back . There is a further fitting at the back mudguard bolt . Inside the pannier I made two toggle bar bolts that fix to bolts that hold the mudguard on . These I made out of stainless hex steel bar that are also drilled and tapped for the toggle bolts . Two toggle bar bolts in each pannier that removes them . Ill try and get a photo .
These are the best I can get you can see the two inner toggle bolts . The bracket goes down the back and under the panniers looped over the bottom stay . The bracket comes off with the panniers stays bolted to them . The two toggle bolts stay connected to the panniers and brackets . Very little can be seen when fitted and they take a minute to take the pair off .
55 Matchless G9
67 BSA B44
06 Ducati 999R
Re: Its Finished .
Post by JohnnyBeckett »
that is very nice now on to the next one :?: :)
keith wainwright
Re: Its Finished .
Post by keith wainwright »
Guy the Goldie looks good well done.
Re: Its Finished .
Once you have got past the usual niggles, it will be interesting to hear your views on how you like riding the Square Four in comparison with the Gold Star.
GuyWalton
Re: Its Finished .
Post by GuyWalton »
JohnnyBeckett wrote:that is very nice now on to the next one :?: :)
Thinking about an HT but have a 67 BSA B44 and a 55 Matchless G9 I need to finish and get rid of first as I havent got the room to keep them all . Maybe next year . But you never know .
55 Matchless G9
67 BSA B44
06 Ducati 999R
Re: Its Finished .
i like the matchless G 9 I think they are a good work horse i can not seem to brake mine it just go on and on 8-)
