Flexible petrol pipe
Re: Flexible petrol pipe
I use plastic pipe with a stainless steel braided outer and clips with a bolt and nut rather than jubilee clips. The result looks good, original at first glance, keeps the petrol where it should be and lasts for years and years.
KenGriggs
Post by KenGriggs »
Just an observation. Shouldn't your tank mounting rubbers be the other way around? i.e.thicker one to the top to support the tank on the frame lug? :)
Brian Petheram
Post by Brian Petheram »
Thanks for all the helpful replies - I've now ordered 12" of the second type which will be about right for my bottom feed float chamber.
Dave.Barkshire
Post by Dave.Barkshire »
KenGriggs wrote:Just an observation. Shouldn't your tank mounting rubbers be the other way around? i.e.thicker one to the top to support the tank on the frame lug? :)
I think you're right. I tend to mix and match to stress the tank the least and to avoid clashes with handlebars etc.
Ariel Red Hunter VH1 1938
BSA L27 1927
Velocette MSS 1939
AJS Model 20 1953
Triumph Scrambler 900
AOMCC Member 3400
Users browsing this forum: ChinniK and 1 guest
