KH Progress
David Smith
KH Progress
State of progress of my KH Project, fromas bought (from the wonderfulPaul Jamieson via e bay), and present condition of the chassis
[img][/img] Best Regards
Dave Smith
Dave Smith
- Eero.Korhonen
Re: KH Progress
It is looking good Dave!
Br, Eero
Br, Eero
Re: KH Progress
Looking good Dave. What are you painting the mudguards and frame with?
Another question if you don't mind. How do you find that lift? I don't have the space for a full size table lift, as like you I work in a conventional garage, albeit with a mezzanine storage area overhead.
Re: KH Progress
Looking very good indeed - keep up the good work!
- PeterW
Re: KH Progress
Looks like one of these https://www.ebay.co.uk/itm/143022260550simon.holyfield wrote:Another question if you don't mind. How do you find that lift? I don't have the space for a full size table lift, as like you I work in a conventional garage, albeit with a mezzanine storage area overhead.
Looks just what I need too.
Re: KH Progress
I shall be in town with the truck tomorrow. Wondering if I should use the opportunity to buy one, or whether I will be forever worrying about the stability of the bike on top of it?
- Bob.Murphy
Re: KH Progress
I have my 'VH' on one at the moment, they are very stable (still best to strap the bike to it).
Re: KH Progress
That looks too precarious for me - I use a Sealey 365 'X' lift:
https://www.sealey.co.uk/product/563719 ... -hydraulic
I remove the ramp when in use which reduces the footprint and when it's not in use it's folded and up-ended to store against the garage wall. Wouldn't be without it.
Re: KH Progress
I have something extremely like the Sealey X lift but without the Sealey name on it, which probably reduces the price somewhat. In its original form it is ok for a centre stand bike but considerably too short for a rear stand bike. So mine has been modified somewhat so that I can just get a rear stand bike onto it by means of an extension to the front. This is not something I would advise others to follow blindly as the action of the X system when raising the table leads to a danger of overturning forwards if you were sufficiently incautious. So as a relatively light and easily moved ramp for centre stand bikes it is fine - but not at all easy to use for a rear stand bike.
David Smith
Re: KH Progress
Simon
The lift is a generic chinese one off of e bay,I find it fine, but have welded a bracket to it that at present bolts through one of the holes in the frame. The standard rubber covers are a bit prone for the bike to slide around and could be dangerous.When I had my BSA B31 special on it I strapped it on which is very necessary. A welded on bracket is better.
Dave
Dave
