Petrol tank cap seal material?
Graham.Goral
Hi folks,
My Huntmaster petrol cap has a slight leak and, on inspection, the original seal is hard and cracked. What material is best to make a replacement please? I know normal rubber will not withstand petrol. Neoprene? Silicone rubber sheet?
Suggestions please?
Cheers, Graham
Suggestions please?
Cheers, Graham
- charles.bulloch
Re: Petrol tank cap seal material?
If it is a 55 tank an MZ TS 250 cap seal fits and is easily available.
roger.fellows
Ask Steve Carter!
bevanclark
I've made them successfully out of a piece of old leather. Cheers, Bevan
- adrie.degraaff
"ALI" has has blades of cork made of a single cut with no bounding material.
- pappleton
Hi Adrie,
I'm having a 'dim' moment. Tell me more about this ALI of which you speak.
BR, Paul
BR, Paul
- robjameson
Cork works and is available in pre made gaskets from eBay etc.
Rob Jameson
AOMCC Member Number 4068
1957 Ariel VH
1954 Ariel KH
AOMCC Twin Spares Organiser
1957 Ariel VH
1954 Ariel KH
- adrie.degraaff
You need a blade of cork becouse the bounding material of the ebay things cann't stand modern petrol.
aliexpress or alibaba.
Viton rubber sheet is available. Cut a new ring of this using the original cork one as a template. Viton rubber is resistant to ethanol, whereas cork will eventually disintegrate in contact with ethanol in fuel. Google it.
Graham.Goral
Thanks guys! Will investigate the MZ tank cap seal first but mine's a '56 bike so I need to check if the '55 and 56 tank caps differ. If so then I'll look at Viton sheet, as I've had cork ones on other bikes which have not lasted very long. Thanks for all the help
Users browsing this forum: ChinniK and 1 guest
