Arrow SAE 20 and SAE 30
Where do you get clutch and geabox oil SAE 20 and SAE 30,or what do you use?
The National Motorcycle Museum do Castrol XL 30 in 1 Litre quantities, but can not find SAE 20 for the primary chain case.
Thanks for any help in this
Bernie
Bernie
Re: Arrow SAE 20 and SAE 30
HI Bernie have you tried www.castrol.com/uk/classics phone 01954 231668 see if they can help they have help me on lots of oils
Many Thanks for the quick reply, will have a look.
Bernie
Bernie
bh.sprint
Bernie phone numbers sent via private messages
Also I use 20 grade fork oil for the chaincase, it's said to have other additives in it but it's been OK for the last 10 years or so in my standard Leader .
Brian H.
Brian H.
Thanks for the phone numbers Brian.
I did find that Castrol do a Classic XL30 Monograde SAE30 in 1Ltr cans, also thy do a Classic TQF Automatic Transmission Fluid 1 Litre which acouding to castrols website "can be used in motorcycle primary chain case where an SAE20"
Both of these are on ebay
Thanks again to all for your suggestions.
Bernie
Bernie
mercedes a class have a chain in auto gearbox and some fords that will be ok to use primary chain case
- grahamhibbs
I've been using ATF in my arrow for 15 years seems OK but I don't do lots of miles
Graham
West Sussex
1942 Ariel w'ng
1928 Ariel Model B
1960 Ariel Arrow
1960 Ariel Leader
1961 Ariel leader cafe racer (under construction)
Graham
West Sussex
1942 Ariel w'ng
1928 Ariel Model B
1960 Ariel Arrow
1960 Ariel Leader
- AndyEames
Atf in the primary.
Penine Oils do an SAE20 which I have used in my Arrow chaincase
Thanks for all your suggestions
Bernie
Bernie
