Square Four Push Rods
Gui.dorey
Re: Square Four Push Rods
Post by Gui.dorey »
Hello again,
John, I might have misunderstood you - do you mean turning down the valve collars? To me valve caps are actually caps that go on top of the valve stem where the rocker arm presses down. Not used here, but otherwise quite common. When you mentioned valve caps I supposed you meant the top of the stem where the collets push against the valve stem.
Cheers,
Gui
1951 Ariel Square Four MKI
1954 Ariel NH Red Hunter
1929 BSA Sloper
1946 BSA B31 (project)
1954 BSA C11G
1960 Harley Sportster XLH
1951 Harley WL 45
Bob.Murphy
Post by Bob.Murphy »
Gui.dorey wrote:I know, I hate to take those guides out and back in again. I will have to check with a mate who has all the machines and more experience to see if he can do something with the guides in place.
If your mate has a Mill it should be easy enough to reduce the height of the guides in situ. The tops don't have to be domed but don't leave them flat to prevent oil pooling around the valve stems.
Now . . . If he has a CNC Mill . . . . . .
Users browsing this forum: Greg.Dobinson, tony.barnett and 1 guest
