Cyclone engine
Cas.vanderwoude
Cyclone engine
Post by Cas.vanderwoude »
selling on behalf of an older friend who is not internet enabled:
1958 Cyclone engine - bottom end, barrels, transmission and a head.
Not sure if the head is correct - I think it might be off an A7 or something because the fins do not match.
I do not know what it might be worth but I do know it is not a common item.
My friend is decluttering to help pay some bills.
best to email me directly - cas.vanderwoude@gmail.com.
Re: Cyclone engine
BSA barrels - look to be the very desirable (as long as not too far off standard bore size) thick flange later Rocket(etc) type. Also BSA rocker box, but I think that's a Huntmaster cylinder head.
A set of newly-rebored +20 thick flange barrels went for over £350 on ebay the other week....
Cas, it might be useful if you could put up the numbers from the gearbox, it could help people to work out what it's for.
Cas.vanderwoude
Re: Cyclone engine
Good idea Simon,
here s the serial number. I'm assuming "CR" is close ratio?
roger.fellows
Re: Cyclone engine
Post by roger.fellows »
I think it would be safer to assume it's the remains of 'GB' , 'M' I think is December, 1957.
Cas.vanderwoude
Re: Cyclone engine
Thanks Roger,
doing a bit more digging and I agree. So the GB44 was the "standard" transmission for a range of heavyweight Ariels in the 1950's?
Mick D
Re: Cyclone engine
Post by Mick D »
Sorry for the hijack, but can anyone tell me the significance of the 'FC' - I have a 58 GB44 similarly marked.
roger.fellows
Re: Cyclone engine
Foot Change???????? ..... More likely 'Fully enclosed rear Chaincase????
