Last nights ride out with a friend, made me consider that i was asking too much from my VH
so first question, " what should i be cruising at speed wise ?" this is going to throw up some sprocket questions i know
but before i answer those (cant do it now i'm at work ) someone on here must have played around and sourced sprockets to improve top end
i feel the bike in its currant set up is good at about 50mph , i've seen 60 but the engine was revving at this speed - still more in it but i don't want to push her to hard
seems to me that the VH is able to pull the side of a house down in its currant set up a i am through the box and in to to top swiftly
and it then pulls strong from 30mph upwards - did swap the primary crank sprocket to 21 teeth (i think) as it was 19 when i bought her
what are the thoughts of the Panel ....? over to you
