DU142 headlamp clip
alan.moore
DU142 headlamp clip
Post by alan.moore »
Does anyone know of a source of these clips or maybe has one,( any condition) they could pass on . Drags have been on back order for a while now
Alan
ian.scott
Re: DU142 headlamp clip
Post by ian.scott »
I'm sure I have a rechromed one somewhere in my shed.
I'll look for it over the weekend
Ian
Post by Paul Slootheer »
Alan found this...
I'am quite sure it is a genuine old clip, but it requires a little repair due to a crack, (see photograph) a bit of silver solder will do the job.
Can give dimensions if required
Paul
ian.scott
Post by ian.scott »
I have found mine but not the cable to enable me to print a picture It is the same but I think the Clip end has been opened out a bit, other than that it is good.
Found it !
Ian
The one on my RH500 I made out of sheet brass in 1990 and had it chromed. So far, it has done the job ok.
alan.moore
ian.scott wrote:I have found mine but not the cable to enable me to print a picture It is the same but I think the Clip end has been opened out a bit, other than that it is good.
Found it !
Ian
Ian,
That looks fine, I will PM you
Paul, thanks for that but the crack may be a problem. Thanks again for posting
Alan
alan.moore
All sorted, thanks for the responses
Alan
