W/NG Rack
- LuisPaz
W/NG Rack
Hi fellows
I live so far in Argentina and the shipping cost are high to buy a Repro Pannier Rack
I make and easy drawing and i need measurements to make my own rack.
They should only measure the length of each red line named with a letter. If possible, the angle shown in the drawing.
I will greatly appreciate the measures that you can send me.
Also i need the thickness of the bar.
Thanks in advance!
Thanks in advance!
Luis, from Argentina
1944 Ariel WNG
1944 Ariel WNG
- LuisPaz
Re: W/NG Rack
Grahan Goral from Facebook Ariel Motorcycle Group help me with all measurement i need to make this rack!
https://www.facebook.com/groups/2809984 ... &ref=notif
A = 430mm measured along top between rear of rack and theoretical intersection point
B = 300mm measured along top between theoretical intersection point and end of mounting lug
C = 475mm measured along underside between welded joint and end of mounting lug
D = 130mm along tube between welded joint and end of mounting lug
(distance between mounting lugs = 150mm)
E = 130mm between centres
F = 130mm between centres
G = 160mm between centre of mounting lug and centreline of tube
(Pannier mounting lugs 140mm between centres)
H = 220mm between centres
Tube diameter = 12.7mm
Angle = 52 degrees (ie. sloping tube is 38 degrees from horizontal)
1944 Ariel WNG
1944 Ariel WNG
Re: W/NG Rack
According to the parts book number, that rack only dates back to 1940. Nev
- LuisPaz
Re: W/NG Rack
Hi Nev
The Parts Manual according to my frame number you can see this rack
1944 Ariel WNG
1944 Ariel WNG
Re: W/NG Rack
That's the rack that comes with the pannier frames, fitted from '42? The earlier rack is more like a civilian one.
The rack Luis shows is missing from my original January 1942 parts book.
Re: W/NG Rack
My parts list is May 1941. Complete carrier Number 5630-40. This is closed at the front and has not got the extra mount points for the pannier frames. The note in the parts book says do not use E9/896 which it presume is a civilian one. 5630-40 was only used for a bit more than a year, it appears.. Nev
- LuisPaz
Re: W/NG Rear Carrier
Thanks to the measures shared here in the forum, I started building the rear carrier. My rear fender has missing parts, such as the hinge, which I will have to rebuild. I'm newby to iron folding and welding, so I have mistakes to correct even ...
1944 Ariel WNG
1944 Ariel WNG
Re: W/NG Rack
HI I think you are making a very good and nice job of that rack and i think it is better made then one you would buy and your one you knows your one fits keep up the good work
Re: W/NG Rack
Good Job Luis !
