1927 A/B rear hub/brake assembly
Is there anywhere where I might find a schematic of the layout of spacers, washers, thin nuts, shouldered nuts etc that make up the rear wheel spindle/brake assembly? The parts list for a '27 B does not really help much.
Re: 1927 A/B rear hub/brake assembly
A most essential piece of information, for any of these bikes. When I get it I print it off and cover with plastic for workshop use. Nev
- cmfalco
It probably won't happen fast enough to help you, but I'm about to start the complete rebuild of a 1928 Model C that arrived at my house yesterday. I intend to extensively document the rebuild, although I haven't decided yet where to post the material. Unfortunately, the AOMCC site doesn't have much activity so it isn't the best choice.IanSlade wrote:Is there anywhere where I might find a schematic of the layout of spacers, washers, thin nuts, shouldered nuts etc that make up the rear wheel spindle/brake assembly?
Why don't you blog it, or post it here on the forum?cmfalco wrote:... I intend to extensively document the rebuild, although I haven't decided yet where to post the material. Unfortunately, the AOMCC site doesn't have much activity so it isn't the best choice.
I've been blogging my last couple of restorations and I'm pleased with the results. For me, it's more useable than the single articles I produced for the Bantam, Matchless and AJS rebuilds.
- cmfalco
Documenting a restoration in a way others will find interesting takes a lot of work so it makes sense to post it where it will be found. There are 25 threads/page on the AOMCC site, and looking back through the Four Stroke section a typical thread gets a few hundred hits. Only ~1 out of 100 reaches 1000 hits. In contrast, I've been documenting my restoration of an uncommon BSA on the BritBike Forum and it's nearing 350,000 hits.simon.holyfield wrote:Why don't you blog it, or post it here on the forum?
Although providing a lot more 'bang for the buck,' unfortunately BritBike Forum makes it very time consuming to post photographs so the thought of starting another restoration thread there is off putting. Anyway, this is why I haven't decided yet what I'm going to do about the Ariel restoration.
Well, FYI I get 40-50,000 hits per year on my blog.
sadly no info forthcoming here. I have ended up using a washer next to the bearing then a 'thin nut' and a short spacer to get the right spacing for the brake plate although I have nothing that is a good fit for the centre hole on the brake plate. Perhaps a bit of lateral movement could be good/ intentional to help braking /shoe alignment? Ring any bells anyone??
Thanks, Ian
Thanks, Ian
Leslie.Ore
Dave Owen is probably a good person to ask,he is on this forum.
john.deeth
Ian,
What are you planning to do for a silencer for your '27?
John, I ordered one from Armours but when it came the bracket was in the wrong place so they are making a special with nickel plate rather than chrome so that it matches the pipe.
