Need a couple of pics please!!
ochosolamente
Post by ochosolamente »
Back from London where I had a fantastic time. It was great to meet Steve Carter. We met at the Jumble in Kempton park and the next day in London for lunch. There I bought a few parts for me 48 VG. I need some pics of the following parts installed so I make sure I got these right.
1. I need a pic of the exhaust lifter where it mounts to the rocker cover. Im confused about which way the lever swings when actuated and how the cable is routed. I may still be missing a part.
2. I need a pic of the air cable (choke here in the states) where it enters the top of the carburetor. Mine is completely missing and I believe the top of the carb, or the complete carb, has been changed which would explain why no lever or cable exists. The top of the carb where the air cable SHOULD go has a screw in its place. I removed the screw but the ball end of the cable is too large to fit in this hole.
Hope this all makes sense. Thanks Ocho
Lets hope well all get to heaven before the devil knows were dead!!
Man will truly never be free until the last king is strangled by the entrails of the last priest!!
Steven.Carter
Post by Steven.Carter »
Sorry Ocho, its not the pic you wanted :D
The lever on the valve lifter is on a taper and when the cable is pulled the lever swings towards the front of the bike. The converluted spring returns the lever back . The trick is getting the lever fitted in the right position so that theres a little play and not pushing down on the rocker at rest. I'll get a picture organised.
Steve
Steven.Carter
If you have no choke cable and lever fitted the actual choke slide may also be missing inside the Carb. My guess is the bike will run fine without a choke slide but if your choke slide is still in the Carb without the cable fitted your bike will try to run with the choke on all the time, not good.
Steve
adrie.degraaff
Re: Need a couple of pics please!!
Post by adrie.degraaff »
Is this what your looking for
There should be a small cilinder end to your cable not a bal.
ochosolamente
Thanks for the pics. As i thought, I'm missing the bracket that bolts to the cylinder head and hooks the end off the funky spring. Here's what i have!
Ill try to put some pics up of my current configuration
ochosolamente
Heres my current setup. Im missing the bracket that attaches to the cylinder head. But, my trusty friend Steve has the bit for me. Thanks again steve!! Pints are on me!!
.....when the cable is pulled the lever swings towards the front of the bike......
On my ariel it moves to the rear of the bike.....it's a 'bowden' cable.
Steven.Carter
Your right Vincent, so does mine. You know what they say, a little knowledge is a dangerous thing!
Yep, I wonder if Ocho already went for it with hacksaw and chisel to get his one swinging to the front
Steven.Carter
Re:
Vincent.vanGinneke wrote:Yep, I wonder if Ocho already went for it with hacksaw and chisel to get his one swinging to the front
That's what worries me :D
