Thanks Bob ! come on! You can do it !!
But.....Today I've run into a problem with the decals for the tank.
I have two sets of waterslide decals for HS/HT bought from the club with a few years in between.
Actually, I bought the second set because I had forgotten I already had a set....
The one I tried today is like the one on the right hand, this one did not wanted to go 'around' the curve of the tankside.
It just sat there like a plank, no matter how I patted it, the folds just kept on popping up..
I used at first luke warm water, then did it again with slightly warmer water as I thought it would make the decal go softer, but none of that.
I dont think the tankside is any more curved then a normal Ariel tank so why wont it go ?
Main difference between the two sets is that one set came with a protective paper over the transfer.
The one with the protective paper looks like it's a tiny bit thinner, anybody having a clue to what to do ?
