1936 cammy rear guard
rodney.mccue
Post by rodney.mccue »
hi I am restoring a 36 cammy I need to know is the rear guard hinged but with a detachable tail piece, also is the tail piece
flat like the 35 or does it have the pattern like the later ariel (1939) any help would be great
thanks rod
brenton.roy
Post by brenton.roy »
Rodney,
I can only help in terms of the equivalent single. The cammy in the brochure appears the same.
If the guard is ribbed - singles were - it isn't hinged. The rear section bolts on.
Brenton
rodney.mccue
Re: 1936 cammy rear guard
hi brenton in the parts book it states 1935 hinged rear guard so I presume it the 36 would be hinged also
but what I need to know is the tail section plain or pattern
thanks rod
brenton.roy
Oops, sorry about that Rodney.
The funniest thing happened. I went out to check the bolt together rear section on my '37 guard and it has miraculously become a hinge.. :o I was confusing it with an earlier guard. No excuse but brain fade.
Hopefully a Cammy owner will know about the section / style.
richard.harvey
Post by richard.harvey »
Can tell you after new year. I have very original 1936 cammy but in storage and I am travelling from tomorrow. Guard is ribbed and I am pretty sure hinged but will confirm.
rodney.mccue
hi thanks Richard your bike looks very good , can you also look to see if the tail section is plain at the bottom or pattern like the later square fours
richard.harvey
1936 Cammy rear guard.JPG (30.94 KiB) Viewed 4401 times
Dear Rodney, sorry this is so late. Pic of rear mudguard and hinge section of my 1936 600cc cammy. Hope this helps. Richard
rodney.mccue
hi Richard that helps heaps now is the bottom of the guard shaped like later ariels or flat like the 34/35
thanks rod
richard.harvey
If you look at the original photo I sent, you can see the shape of the tail of the rear guard. It is not flat. I will take a better photo when I visit my storage site next.
Richard
richard.harvey
36 Cammy rear end.JPG (28.45 KiB) Viewed 4231 times
Here you go. A pointy tail. Hope this helps. Let me know if you want me to trace the shape.
Richard
