Late VH with push-in exhaust pipe.
dick.warne
Over the years the bore in the head gets worn with the passage of many exhaust pipes, so you can end up with a very sloppy pipe in an enlarged 'ole! Almost impossible to seal, and when you throttle back, you get quite a number of people looking round for the source of the explosions! Take the pipe and silencer off, when cold, then clean the pipe/head joint as well as you can, then apply Wickes clear silicon bathroom sealant in the head and on the pipe, then bolt back on the bike. Make sure the pipe/silencer joint is nice and tight, then wipe off any excess sealant. Leave to cure overnight then go for a blast next morning! Works for me, and you can of course break the joint at any time. You can also use this method for the earlier stub-type heads with the push-over pipe.
ben.mitchell
Re: Late VH with push-in exhaust pipe.
I have done the same as Dick with the silicon seal on the exhaust pipe, it has generally lasts a couple of years before needing to be done again, which is no problem as you are more than likely going to be taking the exhaust pipe off for other reasons in that timescale.
Ben
Ben
- chris.vredenbregt
