Touring on a VB
Rob.Bassett
Touring on a VB
I plan (hope!)to do some long distance touring on the VB once it is on the road.Any touring is of course long distance from here in Orkney..
I wondered if any regular VB riders could give me an idea of the fuel consumption I could expect,and what sort of cruising speed/average could be achievable.Of course I have the big shaft drive flat twin for high speed long distance work.....only joking,its a Ural....I avoid motorways whenever possible and have a fair degree of "mechanical sympathy".Any hints or advice (except "don't do it)welcome.Rob.
- Steven.Carter
Re: Touring on a VB
My friend took his 39vb over to Germany for our annual rally , I suppose he was getting around 50mpg whereas my 58vh did about 60, so not much in it. We did a little on the autobahns and he managed to keep to around 50mph although really it was a little on the slow side for such a road,. Have you ever seen a trucks radiator ornament? That's what he looked like from my mirror!
The VB has about the same power as a good 350 OHV but pulls better so the gearbox doesn't have to be worked so much. I don't like to see a SV sitting on high speed as I reckon they are hard on exhaust valves. If you can set up the exhaust valve to rotate slowly as it goes up and down this will help to keep the valve from distorting. A wiggly jigger under the valve spring will do this and use a real good valve and a bit extra valve clearance. To check if your valve clearance is adequate go up a steep hill with the valve cover off and a fair bit of throttle and then stop and check the clearance existing quickly. I had an M20 that wouldn't pull and this found the problem. The valve clearance was disappearing when the valve got hot. Some later metals expand more than the earlier alloys. Nev
- brenton.roy
Re:
Hi Nev, can you explain?nevhunter wrote: A wiggly jigger under the valve spring will do this ....Nev
Also, congratulations on your goldness..
- john.nash
Re: Touring on a VB
My 1947 was a VB, before it got a VH top end.
45mph is really comfortable. 50mph is ok. 55 it feels urgent at and thereafter the tingly vibrations set in and it starts getting hot and bothered. Not that it will accelerate much there.
My friends BSA B31 350OHV was faster. However, the VB has it on the hills; it'll go up those with no trouble.
Probably not the ideal vehicle for long distances, as you're dicing with the lorries at those speeds, with no ability to get away .
However, plenty do distance on them; so what do I know
Manual reckons 65mph top speed and 70-75mpg:
http://www.arielownersmcc.com/members ... ingles.pdf
John Nash
AOMCC No.4119
AOMCC No.4119
john.whiting
- Steven.Carter
- Keith.owen
Re: Touring on a VB
John,
So that was it? Was this murderous thug reporrted? If he wasn't he should ahve been. No one who has such problems with anger management should be let loose with a paper cup let alone an HGV!!
Keith
Keith
Keith Owen
Past Editor - Cheval de Fer
1950 Rigid Ariel VH
1951 Rigid Ariel NH
1952 Plunger KH
1950 Rigid Ariel VH
1951 Rigid Ariel NH
1952 Plunger KH
