Help - my SS49 headlamp reflector is stuck
andrewhawkswell
Post by andrewhawkswell »
Hello all - looking for any tips that anyone may have had who has met this issue before.
I have a Lucas SS49 headlamp that I want to fit to my Ariel Model E 1928. I received the headlamp with the cover locking ring and the reflector loosely assembled and no glass or sealing rubber. I put the parts I have together to check the fit and during this the reflector was pushed home into the body shell to allow the bayonets to enter.
I now find that try as I might the reflector is well clamped into the body and I can't get it free with normal hand pressure, or gentle leverage with a thin tool through any of the three bayonet slots against the back of the reflector rim. Inside the shell there are 3 spring loaded clips which are gripping the reflector rim edge, but I can't see how they work - I feel bit foolish as I would have worked this out but the reflector is now in the way- I don't know if there's a trick to release them; they are holding on for dear life and I don't want to crush the shell or refletor. I could drill out the brass rivets that are holding these clips to the shell but that seems a bit extreme.
Re: Help - my SS49 headlamp reflector is stuck
I imagine you've seen this?
I have an H52 in bits and can go and have a look at it, but I don't have any first-hand experience of the SS49 and it might not help...
andrewhawkswell
Thanks Simon
I hadn't seen the extract you posted. Where did that come from. I didn't think the reflector had any bayonet but I'll try turning it and see if it works. There is a little stamped "TOP" lettering in the reflector so that's good and maybe points to it being the correct type.
It's in the library, generic section, Lucas electrics, 6th item down, about page 6.
