Engine shock absorber spring
Who knows the exact dimensions of the shock absorber spring of a 50’s single cilinder. So inner- and outer diameter, thickness and overall lenght. I just purchased one but is seems to big…
Re: Engine shock absorber spring
Square section springs are stiffer than the equivalent round wire ones. it will be a bit of struggle to get the nut on with a new spring but should be possible without recourse to cable ties and bits of string. I don't have dims though
Roger although its seems to fit onto the sliding member, it it looks to big in outer diameter on the end plate. The spring is not laying within the edge of the spring retaining plate but more on top… is this common?
