The Arrow's getting new crankshaft seals. The strip-out's gone fairly well until the very last item - the centre oil seal.
The workshop manual says that after removing the bearing the centre oil seal can be easily removed with a drift and mallet....
Well, all I've succeeded in doing is knocking the centre out of the seal - it's an original-type double seal and there is no metal lip at the front or back.
I seem to be left with a steel-backed rubber cylinder that it's impossible to get any purchase on.
I can't be alone in having this problem - anyone got any advice? All I can think of so far is trying to burn it out, or maybe burn off the rubber, heat the steel backing to red-heat and jam something under it to collapse it.
Or possibly get the rubber off the steel and put a couple of weld blobs on it to use to knock it out.
Anyone got any better ideas - please!
Centre crank oil seal removal - help!!!
Re: Centre crank oil seal removal - help!!!
A photo would help, how about a blind bearing remover? I have a similar set that's got me out of a pinch several times in the past:
https://www.amazon.co.uk/Moendergo-Bear ... hdGY&psc=1
Ivor Collins
The one-piece seals can be difficult to remove.
The last one I did required the use of a die grinder and a steady hand to cut 90% through the steel case before peeling it out like a sardine can lid
Ivor Collins
I seem to remember that I used a small screwdriver blade hammered in between the outer casing and the case that effectively reduced the diameter of the outer so that something bigger could be used to collapse it.
Just tried a blind puller set but it doesn't want to play...so far. I thought the seal might have shifted out enough to get something behind the steel outer but that doesn't seem to be the case.
Looks like any progress is going to be brutal!
- Bernie Blundell
You could try heating the case with a blowlamp/heatgun, ally will expand fast than steel.
Depending on what you have, I'd mig weld a piece of steel rod into the shell then use a slide hammer with a hook end to snatch it out.
