garycullen wrote: Thu Sep 24, 2026 3:38 am
Alfred, I hope you are aware of some nasty chemicals that can exist in EP greases.
This from a google search assisted by mr AI:
The Attack on Bronze: Instead of cleanly protecting the surface, active sulfur aggressively reacts with the copper in the bronze. This forms copper sulfide and copper disulfide. These crystalline compounds cause pitting, spalling, and rapid abrasive wear on soft yellow metals.
When I refurbished my BA box several years ago now I got some good advice from Nev, a frequent poster here.
I use a locally made up runny grease product without any Sulfur in it.
I believe prenrite make a fluid grease product for veteran and vintage cars without Sulfur.
I use the locally made up one in my 1933 Austin 10 steering box and the BA box on my VB. So far no problems.
Hi Gary thanks for your input. I'm aware of this. The manufacturer of the SIL GREASE L-EP 00 actually states a copper corrosion result of "Class 1 max. after 24 h at 100°C", according to ISO 2160 / ASTM D130, which is reassuring. However I’ll try to replicate at home, but using a piece of bronze as well as copper, cover them with grease and just leave them at around 100°C for several days, checking for staining, darkening, pitting or any other surface attack.
It obviously will not be a certified test, but it should be a useful comparative check. I'll try to look in the boxes if i can find the old bushes and use them for the test.
I’m a chemist by training, so I quite enjoy this sort of thing anyway! I’ll post the results here once I’ve done it.
Thanks also for the warning about active sulphur, that was precisely what made me look more carefully into the grease specification before filling the gearbox.
