'54 NH front brake cable wanted
dennis.t
Does anyone know where I can buy a front brake cable for a '54 NH part number 6480-46?
Drags are out of stock.
Thanks, Dennis
Thanks, Dennis
1955 VH500 alloy head
1955 NH350 alloy head
dennis.t
Re: '54 NH front brake cable wanted
Dave,
Thanks for that.
Looks like they are on holiday until 18th August. But if I have no luck elsewhere In will contact them later.
Regards,
Dennis
Thanks for that.
Regards,
Dennis
That's what I've been doing lately. The Draganfly kits are good value.
dennis.t
I looked at Venhill’s site but did not see brake cable kits. Are there other suppliers?
Dennis
Dennis
Don't make it too short.. Before you Play with inner cable, tin it with solder to stop the strands spreading. The eventual soldering requires the end of the cable to be spread for security and strength. It must not be able to Pull through under Normal Operation.IF you are using your front Brake it's because you need to. Preferred flux is non corrosive or else wash in hot water fully Blow of with air and oil it. IF you can purchase the real article it would be worth the extra money to do so. Nev
Some later front brake lever assembles incorporate a cable adjuster. Nev
dennis.t
Nev,
Thanks for the advice and tips.
Dennis
Dennis
