Re: CP gearbox
david.anderson
Re: CP gearbox
Post by david.anderson »
Can anyone provide dimensions for the gearbox sprocket spacer 3112-33 for a CP gearbox, in particular the length, thankyou
david.anderson
Re: CP gearbox
I found an older post by Alan Moore which gives the width as .762" whereas the BA spacer is .435"
viewtopic.php?t=9604
Re: Re: CP gearbox
It makes sense that it would be longer. It's usually worn where the seal runs on it as it's not hardened, so I usually make a new one as a new old stock one would be soft also. The sprocket retaining nut when tight with tab washer ends up with the sleeve gear threaded end about '020" Proud. Nev
