This is my clutch. Vh500
Rick Hughes
Post by Rick Hughes »
Iv just got this ariel recently and when kicking over the clutch slipped now and then. So I decided to have a look
The more I look at this bike the more I realise its going to have some odd things with it
I dont have a lot of info from the guy I got it off. Except it was built for hill climb competitions many decades ago
The carb is rather big it came with a home made clutch side cover that looks mean and this clutch has all the bolts loose. I might need to go a lot deeper into this engine
Rick Hughes
Re: This is my clutch. Vh500
I seem to be failing at adding a picture i thought it was on. Ill keep trying
Maybe this can be seen.
Looks like a Burman/Ariel clutch with added lightening!
Here's what they normally look like...
With standard springs, the tops of the springs should be level with the tops of the cups, or thereabouts. Yours might need tightening down somewhat - if it's slipping.
It is worth checking that the plain plates are flat
