Re: CP gearbox
david.anderson
Re: CP gearbox
Can anyone provide dimensions for the kickstart ratchet pinion bush for a CP gearbox, part no 3193-33. In particular the length of the bush and any shoulder on the bush. Draganfly are currently out of stock. Thanks
Re: Re: CP gearbox
my list jumps from 3191-33 to 3194-33.
3194 is 184x the bush, that one ?
david.anderson
Re: CP gearbox
Vincent
Ops typo there. yes the part no is 3194-33
thanks
thanks
Re: Re: CP gearbox
Hello David,
Steel bush:
Steel bush:
david.anderson
Re: CP gearbox
Vincent
thankyou very much, that is just what I need. it will now not take long to make one.
david.anderson
Re: CP gearbox
Vincent
Sorry but wrong bush. I should have looked at your photos.
The bush that I need dimensions for is the bush that goes onto the mainshaft behind the nut, and the ks pinion gear freewheels on it. Just the length and whether there is a stepped shoulder for the spring. If so the shoulder dimensions.
Re: Re: CP gearbox
that 'floating' bush that works with a light spring ?
Re: Re: CP gearbox
this one I think..
No shoulder just a straight piece of 'tube'
not made from PB steel (PisBakkenstaal) urinal steel
but something better!
david.anderson
Re: CP gearbox
Vincent
thanks
yes that is the bush I was after. a quick lathe job will have it.
thanks again
thanks
thanks again
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
