SQ4 MK1 primary chain case oil level
Duncan J Robertson
Post by Duncan J Robertson »
I am obviously missing something here, but unless the chain case has only half the level of oil in it down from the level plug, the oil is lost while running, I don't lose anything when the engine is stopped.
Have I missed an oil seal at the back of the chain case, if I have it was not there when I stripped the engine, and can't see one on any drawings
Duncan
Re: SQ4 MK1 primary chain case oil level
You're not missing anything. As the saying goes “they all do that sir!"
Duncan J Robertson
Thanks Simon, as I have the engine oil tight I can go back to the old adage for the chain case, when it stops leaking put some more oil in.
Chris Sealy
Post by Chris Sealy »
When I rebuilt my Mk1, I found that oil was leaking out along the bottom two clutch dome screws. On investigation I found that they are not blind holes; and are below the oil level.
Mick D
Post by Mick D »
Just curious, is the square four primary different from most classics which operate best with the oil just touching the bottom of the chain run and if so why?
Duncan J Robertson
Think you are right Mick.
If the level plug was 1/4" lower the chain would not be drowned in oil causing the problem
Happy days.
Duncan
