Electronic ignition
General electrical problems
Vic.Araujo
Electronic ignition
Post by Vic.Araujo »
1946 VG500. After a full rebuild, I want to convert over to electronic ignition. Dragonfly appears to be on BO plus they mention the switch and coil aren't included. Where can I get a complete kit for my bike? Thanks all. Vic
Re: Electronic ignition
Do you feel a compelling need to do that? You can still rebuild the Originals and what if the MOD. becomes an orphan? Nev
Ministry of Defence??
I agree, there is nowt wrong with a good mag and are more reliable than the dynamo that an electronic will be relying on.
cmfalco
Post by cmfalco »
Roger Gwynn wrote: Fri May 22, 2026 8:53 amthere is nowt wrong with a good mag and are more reliable than the dynamo that an electronic will be relying on.
Other than relying on the dynamo, voltage regulator, and battery, what could possibly go wrong with an aftermarket ignition system?...
cmfalco
Post by cmfalco »
Semi-(un)related to this thread, several Ariel club members attend the Irish Rally so, FYI, at the upcoming event I'll be giving an evening talk on "Troubleshooting, and Maximizing the Performance of Your Magneto."
Mike Nash
Post by Mike Nash »
I hesitate to criticize the opinion of m’Learned Friend, Professor Falco, but his favouring the magneto and his gentle mockery of the use of “the dynamo, voltage regulator, and battery” all necessary to support an “aftermarket ignition system” must not go unchallenged. For when disguised as “Magnetoman” on the Britbike website he said “that I’ve never looked inside a restored one that was functioning properly” and then over many pages went on to describe the complicated “steps […] necessary to return a magneto to its original performance”.
The complexity of restoration and the high level of skills necessary to achieve it made me think that such work was beyond my reach, and the costs asked for such work would not be sufficient for the claims that are made. So at the moment I’m going the aftermarket electronic ignition route. But that said, I’d favour the path demonstrated by Bob Brassington (of happy memory) of converting a dead magneto to drive a coil. I have the article taken from an old Cheval magazine (of the early 2000s I think – alas, the issue dates weren’t printed on each page then), a path which I believe to be much more satisfactory. Has anyone done this recently?
Finally, I’ll say that in many decades of classic cars I’ve never known anyone want or propose to replace their coil systems with a magneto. I rest my case, MikeN.
cmfalco
Post by cmfalco »
Mike Nash wrote: Sat May 23, 2026 8:10 pmwhen disguised as “Magnetoman” on the Britbike website he said ...
How dare you use my words against me! Sigh...
On the subject of magnetos and old cars, as a result of questions asked of me when I participated in a 2023 cross-Arabian-Peninsula rally for pre-1975 cars (some as old as pre-1910), I expanded my "master" magneto talk to include more material specific to cars, allowing me to tweak the content for that audience. If it's any consolation, the magneto-powered car people on that rally had the same issues with rebuilders as motorcycle people do.
cmfalco
Post by cmfalco »
Mike Nash wrote: Sat May 23, 2026 8:10 pmI’ll say that in many decades of classic cars I’ve never known anyone want or propose to replace their coil systems with a magneto. I rest my case,
I've been reflecting on your post and, not to say you're wrong about your own decision to switch to an aftermarket system, but the case you made is flawed. It's been my observation that most people who wouldn't hesitate to rebuild a Norton Manx head in the car park at night, would throw up their hands in helplessness at the thought of diagnosing an ignition problem. Aside from anything else, the electrophobia factor alone would eliminate the thought of a magneto conversion from the minds of most classic car owners.
Also, unlike motorcycles, by the mid-1920s the major UK and US automobile brands had adopted electric starters, so they already relied on a dynamo, voltage regulator, and battery. Again, aside from anything else, this factor alone would eliminate the thought of a magneto conversion from the minds of most classic car owners.
Mike Nash
Post by Mike Nash »
Hmm, “flawed”? Gosh, you cut deep, sir.
And how did you know about the Manxes? (It wasn’t in the carpark but it’s true I was holding the torch at the time.) Long ago and far away I was my cousin’s mechanic for his Nortons, but I suppose you already know ‘cos your spies are everywhere. (And always have been.) But it wasn’t “. . the thought of diagnosing an ignition problem” that was the difficulty, for in the 60s we all had old vans for bike transport (the money was spent on the bikes) and these old beasts had their share of electrical and ignitions failures. It was the complexity and our lack of skill in sorting magnetos, skills we didn’t need because of their inherent reliability. In contrast, distributors, coils and batteries are easy to understand, diagnose, service and to repair or replace. And they’re reliable, indeed, my 1963 Morris Minor (which has been in the family since 1965) still has its original distributor, condenser and coil.
Regarding magneto overhaul, a search of the interweb showed that there several firms in the UK doing this for aviation, so the skills exist. But its expensive, being at about a £1000 in 2020 (about £1250 now) for a Piper Cub and that’s for a magneto that’s been regularly serviced all its life. And even In aviation circles they remain a “black box”. Long ago, a fitter on Shackletons told me that “. . it’s a little box of sparks. You turn a little handle and you take out a spark. You do that for a 100 billion times and then they’re used up. Then you fit another little box”.
But enough of this drollery. I’d rather focus on the Brassington Modification wherein the armature coil is stripped from the magneto shaft and a wire attached between the points and the slip ring, so it switches both an external coil and condenser. Has anyone done it?
Regard to all from MikeN.
PS Above my dates are adrift for I see that in the Cheval de Fer of Aug ’96, a Jeff Evans has done the magneto mod and says that it “ . . is super and easy to do”. Who he?
A magneto is a fully self contained creator of High Voltages AND Needs NO Battery. The best has a rotating Magnet. You can also Have a low tension with a remote coil near the Plug. All these rely om Breaker Points. The Magdyno supplies DC voltage as well and that with the drive can cost a fair bit to get to good condition. The days when you could buy New Old stock Magdynos are long gone . Nev
