Semi Fluid Grease for Gearboxes
Keith.owen
Post by Keith.owen »
Hi,
I have always used Penrite semi fluid grease but it is now becoming hard to come by.
Can anyone suggest a good alternative? Also do people mix their own and if so, what is the recipe?
BR,
Keith
Keith Owen
Past Editor - Cheval de Fer
1950 Rigid Ariel VH
1951 Rigid Ariel NH
1952 Plunger KH
Re: Semi Fluid Grease for Gearboxes
I use https://draganfly.co.uk/shop/83795/gear ... 11/#OI-GRB well I would, wouldn't I. 750ml rather than 500ml of the Penrite
I use the Morris one - K400EP?
Alan G
Post by Alan G »
https://www.ebay.co.uk/itm/391925159143 ... R_q7waygZw
I have a tub of this, not used it yet - but expect it will be fine, blurb says it is for vintage car and bike gearboxes, and is under a tenner....
dave.owen
Post by dave.owen »
Keith, you could pick some up at kempton park auto jumble
Dave
I usually mix my own with Tacky Mill grease and a thick gear OIL. The Penrite Product is easily available HERE in Au and the exchange rate is very much in the UK's favour,. As long as it POURS it will not channel. Nev
klaus gerhard
Post by klaus gerhard »
I get mine from a local tractor repair shop. They charged about 11 Euro for 1 Kg.
Keith.owen
Hi there!
Thanks for the suggestions; I don't want to do something that i will later regret!
Much appreciated.
keith
Keith Owen
1950 Rigid Ariel VH
1951 Rigid Ariel NH
1952 Plunger KH
volker.halbach
Post by volker.halbach »
I am using grease with viscosity NLGI 0 (there are also the more liquid grades 00 and 000); others use NLGI 00. I top up the gearbox with a syringe.
fpassmore
Post by fpassmore »
Here in North America I have started using the John Deere “ Corn Head Grease “. It is available quite readily and a 01 grease so quite fluid. Pricey but the best availability here although I have an acquaintance who is a vintage MG owner and I have used his contacts a few times.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 8 guests
