Mag choke lever rebuild kit
Re: Mag choke lever rebuild kit
Bit of a challenge to getting the set up to work as it should. The valve lifter bit can work with Little or No drag.. Nev
My valve lifter is on a single lever. The dual lever I have issue with is for choke and magneto..nevhunter wrote: Thu Mar 19, 2026 2:27 am Bit of a challenge to getting the set up to work as it should. The valve lifter bit can work with Little or No drag.. Nev
