Hoping someone can shed some light on this.
My KH500 smokes as though it's wet-sumping permanently.
To side-step any answers about rocker-gear over feed, please note that my engine has all the fixes for that, i.e:
- Restrictor in the rocker feed
- Club tappet guides with larger drain channels
- Valve guide oil seals
Oil return flow appears normal.
Oil pressure is good, >90psi when cold settling to 25psi warmed up.
I have tried a couple of thing in order to diagnose the issue:
- Disconnecting the rocker feed, in case the usual fixes haven't worked, and drip feeding the rockers manually
- Bypassing the Morgo filter in the return feed in case that was restricting flow
- Temporarily adding an electric return pump via a banjo bolt in the sump plate drain, in case the return pump is weak
I've also tried running total loss and letting the oil just fall out, by removing the sump plate completely, again in case the return pump is weak. Strangely, almost no oil came out until I stopped the engine, at which point it poured out. Now this may be because the engine is breathing through the large hole and the updraft, coupled with the centrifugal action of the crank, is keeping the oil away from the aperture. The same might have also been true with the electric pump connected because that seemed to flow much less than the return pump.
It basically looks like there's far too much oil in the sump or just splashing around and it's getting past the rings, so much so that burned oil is dripping out of the left exhaust joint. Surely that much oil can't come from the valve gear. Even if the seals weren't working you'd only get a slight blue haze. My race bikes have much slacker valve guides and no seals and they don't smoke at all.
What would happen if the pressure relief valve was stuck closed or not bypassing enough? Normally the excess oil bypasses into the timing chest and drops into the crankcase, whereas if that path was blocked, would there be massively excessive spray out of the big ends onto the bores which the scraper ring can't cope with?
The Ariel KH handbook states that the pump can deliver 4 times more oil than is required, so if all of that is spraying out of the big ends could that be it?
Has anyone else had this issue, with any model?
All suggestions and comments welcome!
