Vh500 Gaskets
Alan G
Vh500 Gaskets
Post by Alan G »
I have a significant amount of oil coming from somewhere around the head.... Iron twinport head.
The rocker cover gaskets look intact, but old. I removed, cleaned and smeared with grease before putting the covers back on - gut there is still a lot of oil getting everything nicely rust proofed.
There is a fair degree of wiggle on the decompressor. But I have not yet done a talcum powder check to see if I can find where the oil is coming from.
So... planning on replacing the gaskets - are the 1.2mm flexioil ones on ebay any good ? - about £5 a pair delivered.
Is there a serviceable seal on the decompressor? Is "wiggle" normal or should it be tight and rotational only?
Any other "must look at"s?
Re: Vh500 Gaskets
Post by will_curry »
Originally there was a spring pulling the valve lifter spindle into the body of the valve lifter and against a taper
on the side of the lifter body inside the rocker box. A little fine grinding with fine grinding paste might restore
things somewhat and help stem the flow. I've also had a fair amount of oil come out of the thread where
the valve lifter body screws into the rocker box and, being really cheerful, I've got a rocker box with a nice
big crack into the thread.
It's worth checking too that the unions in the oil feed to the rocker boxes aren't leaking.
Re: Vh500 Gaskets
Post by JohnnyBeckett »
hi i use WELLSEAL on my gaskets and no leeks :D :D
Users browsing this forum: charles.bulloch and 0 guests
