Lapping my float needle completely cured the problem for me. But, use very fine paste and limit how much you lap because, to some extent, lapping results in the effect shown at the right, exaggerated here for visibility.MarkO wrote: Sat Jul 12, 2025 5:58 pmI'll have a go at lapping the needle into the seat with fine grinding paste and then tapping and rotating the needle.
I would be reluctant to try to improve things by tapping, since it will be extremely difficult to have the needle and seat precisely perpendicular to each other when you tap it, which only will make things worse. Actually, there's a good chance tapping will make it irreparable. If lapping alone doesn't cure the leaking it already may be beyond salvaging, since some previous owner might already have distorted the seat and/or needle by tapping.
