SQ4 Timing Chain Tensioner
DaveH
Post by DaveH »
Hello all,
It seems my Mark I timing chain tensioner blade (2110-31) is broken, and new ones are out of stock at Drags.
In some earlier posts, it was suggested that the later Mark II design for a duplex chain (2110-56) might be used instead, even with the Mark I single-row chain. This is apparently a single rigid part, replacing the flexible blade, spring and backstop assembly used in the Mark I design.
Can anyone confirm this works? Does the later style tensioner bolt in where the backstop (2119-49) is now?
Thanks,
Dave
chris.shearwood
Re: SQ4 Timing Chain Tensioner
Post by chris.shearwood »
Hi Dave,
I see on my spares list that I've got a couple of used 2110-31 tensioner blades. If you may want one of them, I'll dig them out and take photos. I can't remember off hand their condition.
Chris
1946 4G and 1951 VH
DaveH
Post by DaveH »
Chris,
PM sent, thanks.
Dave
DaveH
Post by DaveH »
To follow up on this question,
  • Chris is graciously sending me a used Mark I style blade, so all is well (thanks Chris!)
  • I posed this question to Draganfly, and received the following very useful information:
    "I've been down to our workshop to investigate the possibility of using the Mark II duplex chain tensioner (2110-56) on a Mark I engine.
    I was initially unsure if this was possible, but with the help of our senior engineer, we have physically tried fitting the 2110-56 into a Mark I case. We can confirm that it is indeed possible. All you would need to do is replace the stud already fitted with part number 0215."
Dave
