Gear change spring
Stephen Pitts
Gear change spring
Post by Stephen Pitts »
Can anyone tell me how the gear change spring is attached. Colt burman gearbox.
Re: Gear change spring
If it follows the same pattern as the GB box that spring will be fitted to the inside of the cover plate, probably with the ends being kept sprung apart so that it fits over the selector plate. As the plate moves up and down it would then engage with one end of the spring in each direction.
(Not that I've never seen the insides of a Colt Burman box!)
The thumbnail pic needs to be rotated 90 degs clockwise, the full -size pic is the right way around.
(And with admin hat on moved to 4-stroke section 'cos this is definitely 4-stroke technical...)
Post by JohnnyBeckett »
hi, maybe you can try Goff Brown the clubs gearbox and clutch spares he will know he is very good and helpful
I think Geoff Brown's services might be intended for Club members...!
hi THEN IT Maybe time to join the AOMCC to get a lot more information on Ariels and club parts
